- Oct 15, 2020
- Maryland
- 2.9 V6
- Manual
- Tire Size
- 32/11.5R15
OK, back in July I bought this truck. At the time the transmission had been removed to replace the infamous slave cylinder but the owner had given up and parked the truck for at least 3 years before I towed it home. Upon arriving home I installed a new slave cylinder, put fresh gas in the tank and a new battery under the hood and started it up. The starter relay stuck on the very first crank, but only once or twice after that (maybe once every 50 or so starts). It drove perfectly fine for about a week (500 miles) then started having issues. I won't go into those here but they were all fuel/spark related, and ended with me replacing the ECM for an aftermarket one (something I had been wanting to do anyway). In the process of tuning this new ECM (which involves a lot of stalling the engine and restarting) I started to notice the starter grinding a little. After some research I learned that the starter bolts could be loosened and the starter pushed back into the block to fix it, which it did. But the noise came back not long after (maybe 20 starts?). Repeating the procedure helped, but each time the grinding came back a little sooner, untill eventually it was basically impossible to start the truck. I'd like to say I'm really not the kind of person to throw parts at a problem like this, but around this time I was supposed to be driving somewhere in a few hours and didn't really have other transportation so I went ahead and put another starter in it, advance auto only had a reman one but again I was rushed so I bought it and put it it. It cranked great for about 20 or so starts but then went back to grinding, regressing much faster than the first starter (This time less than a day). So the next day I pulled the starter and noticed a ton of play in the shaft, the gear could probably wobble close to .1". So I took it back to advance and they replaced it, this one seemed much better. I put it in and exactly the same thing happened, it started great a few times then very quickly regressed to just making a grinding sound when you hit the key. Just now I pulled this starter and found both the ears where it bolts to the block had cracks going through them...
So that's about where I'm at, The truck is a 2.9 obviously, 4x4 with a 5 speed, around 150k miles. Here's a picture of the flywheel:
http://0x0.st/iGhL.wav
http://0x0.st/iGhL.wav Here's the sound the factory starter was making right before I replaced it. Hopefully some of you have ideas.
. But I'm %90 sure that issue is resolved at this point, I could check with a timing light if the #### thing would crank over.
