stalling problem
My '86 2.9 with the ,same tranny does the same;runs when cool but dies when hot,also shifting probs,back and forth between 2nd &3rd .No probs when cool.Going through various sensors and vacuum lines,found several disconnected.Someone said check sensor or module connected with distributor.Any ideas? Sounds like tfi.Great tutoral on link.Thanks.
you may have a vacuum modulator on the tranny issue
these things really like all their grounds and vacuum lines connected
.It runs fine when cool and shifts normally,however the tranny was replaced several years ago.I'll check the vac &grounds.Thanks.
the newest map sensor i got was bad . they replaced it and that seemed to fix that problem for now. so good luck!!
