Stall/sputter
Sorry j didnt read the rest of your post. I found it. Tried to clean it up but more than likely gonna end up taking the upper manifold off there's black crap all up in there. I cleaned it all the best I could, but what's the best way to clean these things?
if you take it apart. brake cleaner to do the job ,otherwise the spray seafoam as calling(deep creep)
like CRC MAF Sensor cleaner
and throttle body cleaner also for clean the rest of material
[ I sprayed a moderate amount of cleaner onto a clean cotton shop towel and cleaned the throttle plate valve. Then, I used another clean shop towel to help prop the valve open (push the valve on the top part towards the engine, as the valve swings) so I could wipe the back of the valve and more of the valve body distal to the throttle plate valve (I could reach about 2-3 inches past the throttle plate valve). I would recommend wearing vinyl/latex/nitrile gloves as this cleaning portion is rather messy with the sludge from the engine. And remember, don't clean the engine if it's hot, as you WILL burn yourself!!!
Reassemble the parts in reverse order of disasembly. Reconnect the battery. Congrats, you're done and ready to reap the benefits your work!]]]]]] :icon_thumby:
