spring spacers
gettle03FX4LevelII
Harrisburg PA
where can i get spring spacers for a 03 ranger 4x4? i just my new 33x12.5 pro comp AT's on and they rub pretty bad. do they tend to run a little wide? they are on 15x10 with a 4.5 inch backspace. i can only turn the wheel about half way and they rub on the stock fender flares and on the body. im pretty sure the torsion bars are cranked up. what would be your best suggestion and quickest. thanks in advanced. would 2 wheel drive spacer work for a 4wd
well you already have the stock rear blocks so i would go about getting some add-a-leafs or shackles. as for the front, if you didnt do a torsion bar crank, then they arent cranked. what i did was cut the corners of the flares. but then again i am using 15x8 rather than 15x10s.
yea cranked em still rubbing had to take the flares off and i am still rubbing on the lower valance still unsure about what i want to do
