- May 10, 2010
- haida gwaii
I would agree, however it seems that no one really reads the stickied threads.
isn't this the truth!
when explaining spring rates,i find that most people get the basic lbs/inch concept,and can usually get the idea of base compression (the difference between full droop and ride height)through-though on this one i like to figure in an inch or two of full droop preload so the spring never becomes fully unloaded-but what most don't seem to get is the leverage effect of the ttb arm(or any suspension arm that is pivoted off the frame and carries the spring,for that matter).it was good to see that specified.
there is one thing to add for those who want to get picky-the main beam does not act as a single piece in this system.it is actually working with the radius arm as a single large swing arm assembly,so to calculate spring leverage you need to draw a line through the two pivots in the system(beam pivot/radius arm pivot)and strike a line perpendicular to this hinge line that goes through the tires contact point on the ground.the distance between the pivot line and the tire that the spring sits at is the ratio you use to calculate spring rate.
by playing with the numbers you can see how extended radius arms can affect the effective spring rate.
longer radius arms stiffen the spring rate.
