- Mar 14, 2010
sound like ignition controll module bad coils and heat will kill em
Crank angle sensor is very heat sensitive. They get their signal off the crankshaft pulley so it will be located somewhere around the CS pulley. I don't know if they are go/no go or if it could produce your symptoms, but without a proper signal from the CKS the PCM won't signal the coil pack to fire. I think all you can do is test the resistance at certain temps and compare to spec.
