spindle lift
06RangerXLT
Georgetown Ontario
can somebody educate me on these for my 2wd coil suspension? and also where to get them.:icon_thumby:
stylintrucks.com
I can't vouch for earlier models, but from 2000 on 2wd with coils up front the spindles are not interchangeable with torsion bar systems. the upper ball joint is smaller on the coil spindles. the upper control arm does not have a replaceable ball joint (on the coil systems) so the entire upper control arm would need to be replaced,,,BUT, the torsion bar compatable control arm is bigger and will push the top of the spindle out about 1/2". not sure if the holes in the frame can accommodate the extra 1/2", plus it will alter the steering geometry.
Perry
From my understanding, they're a sort of drop bracket for the wheel. I thought they used just all other stock suspension parts, but the hub and wheel bearing and all is just lower (3" on most systems). And aren't terribly expensive. About $400 a pair plus shocks, not a bad little lift kit at all. I really want some actually. I just leveled my truck and I have lift fever haha.
