Bootz1385
- Feb 18, 2021
- Columbia,TN
- 2.9 V6
- Manual
I have a 1986 Ford Ranger 2.9l Manual with a 3.73 gear in the rear. I dropped the tire size down to a 195/60r14. The speedo was way off as they had oversized tires on it. The worm gear is yellow and I am guessing it is stock, so 7 teeth. The speedo gear is red, so 21 teeth. From the calculator it looks like I need a 23 tooth as 2 teeth is normally 7 mph. Any one Know where I can get a 23 tooth for the ranger. I saw some on summit but they are for a t5. Thanks in advance.
