Speedometer doesnt work till i get to 30mph
akacabbage
Kansas City, Kansas
I have a 99 2wd ford ranger and the speedometer (also the tripometer (assuming the odometer doesnt work either)) doesnt work untill i get to 30 mph. Does anybody know if '99's have cables or not?
Check the speed sensor on the rear end.. Most of the time they go open. you can check it with an ohm meter..
Abs sensor has to do with speedometer? Sorry I'm a bit of a noob when it comes to mechanics. My speedometer does the same thing but doesn't work at all most of the time. When its cold out, in winter time lets say, it works 100% until the engine bay and cab are warmed up. Then it quits. EVERYTHING works except the speedometer and odometer after that. The sending unit has been replaced at the transmission and had a shop look at it and they cant figure it out. I was wondering, maybe I need a new cluster? Maybe some of the solders only work when they are condensed from the cold then break apart when warm? Any help would be great.
AS well, my ABS has been disconnected. I bought htis truck from a dealer and had them safety it etc. When I got it the ABS light was on and ABS doesnt work as I can lock up my wheels. I hate ABS anyways but if it has something to do with speedometer its going to be a complicated fix? Anyone know?! Its a 96 Ranger 2.3L 5 speed.
i dont remember when the ranger went to an electronic speedometer. it would either be in '95 when they switched to OBDII, or in '98 when they changed everything else. someone refresh my memory :buttkick:
but yes, the speedometer is run off of the ABS sensor in the rear differential on models with electric speedos.
Hmmm, it's weird though. It comes on when cold and doesnt work when warm? And I'm 95% sure they replaced the sending unit on it. Did the same thing with old and new unit.
My 98 Ranger is doing the same thing..never paid attention to the temperature though. It happened a little while after my cruise control was deactivated due to recall....but I think that is coincidental. Sometimes the speedometer works....usually will go up to 60-65..then just cut out to 0....it will usually become active of and on while I'm driving...but my truck has had 165 miles and change for about 2-3 months now....so it usually is not working. I replaced the VSS sensor on the rear trany ($30 at Ford) but that seemed to do nothing.....followed the cable to where it enters the truck under the driver for obvious gorund hazard but found nothing. Removed the instrument cluster to see if I could find an obvious problem..since I'm no wiring expert I was basically hoping to find a mouse chewing a wire! I did bang the cluster once and now my radio will suddenly go out of tune while driving....display will show random things...once it said "call". Anyway it's going to the dealer Monday as I am at the limit of my limited skills....I'm not thay hopeful...anyone have any ideas? I've seen some posts that point to the "GEM"..is that common? Is that an "do-it-yourself" job? Thanks.
