speakers wiring
fap13
i need to locate the factory wires for the speakers for ranger 1996 rear speakers
at which end? the radio: just remove it from the dash. the speaker end: take off the trim panels (and if it has speaker remove them) there will be a plug there in the hole for the speakers.
as far as in between goes, remove the sill plate on the drivers side and there should be a bundle of wires under it. not to sure of wire colors off hand, but I could look that up tomorrow for ya (actualy at this point it would be later today)
If I remember right.....If the truck did not come with rear speakers the harness stops in the passenger kick panel. Its a square grey 4 wire plug wih the same color wires as the radio harness in the dash. Hope this helps.
