Spark plugs other than Autolite
What brand of spark plugs would you use now?
  • AC Delco
  • Bosch
  • Champion
  • NGK
  • Other
Results are only viewable after voting.
I used to really like NGK for my Honda. But of the last 6 I've bought from the local O'Reillys over a few years 4 of them didn't work out of the box...
Motorcraft has never been available locally. (Even by special order.) I used Autolite in the truck 'cause I thought they were manufactured for Motorcraft. If that's not the case anymore, who is?
Autozone should stock Motorcraft
I see that now. Only $7.50 each too for SP-486X. Anybody know what the double platinum part number is for the 4.0 OHV?
NGK, Denso, Bosch, and Autolite supplied Motorcraft spark plugs for the 4.0. Any double platinum or better will work.
Once I put NGK V-power in the 2.9l I stopped shopping; stayed with them since 1990:
• plus 2 heat ranges in stock
• minus w heat ranges in hi compression
If I can't source The NGKs, I will use Denso.
As much as it pains me i do use NGK in the quads.
Motorcraft in the vehicles
I run Motorcraft in our vehicles (all Ford) and Champion in my tractors.
Champion catches a lot of heck but they work great for my old junk.
NGK in my weed packer (which is OEM)
Genuine Denso or NGK basic copper plugs all day long. Same with oxygen sensors, only Denso ( ND ) or NGK. Autolite plugs used to be horrible. Champion and Delco plugs weren't much better. Never used Motorcraft. I was a Bosch man since my air cooled days, until Bosch became garbage in the late 90s-early '00s.
People should read Dr Jacobs book about optimizing your ignition system. It's far better to index your plugs and change them frequently. There's no benefit of expensive plugs other than the idiotic idea of keeping plugs inside the cylinder head for 100,000 miles to appease Consumer Reports average yearly maintenance costs. I'd rather frequently change and read $2 plugs than buy $10+ plugs and keep them in until they seize up the threads.
Upcoming TRS Events
