franklin2
Did you say what ignition setup you are using? Stock with the computer? Converted to a DSII distributor? If DSII, what ignition module are you using, DSII or HEI?
I can tell you if you converted to DSII and are using a rebuilt distributor from Cardone, they are junk. I ended up having to rebuild mine. I just re-installed it the other day and have it running pretty good now. I have been running the stock computer TFI distributor for the last year, with just locked timing. Believe it or not, it runs sort of ok like this, enough to get to work and back.
