Sony in 93 ranger
titanmax
Hi - Happy Holidays
I have a 93 ranger Ext cab with a JBL premium stereo, OEM just coming out. 4 speakers (5x7)... Putting in 2 6.5 and 2 7x9 sony speakers with an inexpensive Sony radio.
Got a wiring harness for the truck and splicing that to the Sony plug.
1 square connectoroff the truck is for the speakers, these line up.
the other truck plug is a gray connector and has more wires than is left on the Sony.
The sony only has power (red), ground (blk), and yellow (memory).. (also blue for power ant.. not using this)
The new wiring harness with the gray plug has 5 more cables,
1 - amp on
2 - amp ground
3 - Illumination
4 - dimmer
5 - blue power ant.. (this not an issue)
Problem:
If I cable the speakers to the radio DIRECT, they work, if I use the truck cabling, they dont. Seems like I need to do something with the 2 amp wires??????????
You won't be using the illumination or dimmer wires. Just tape them off and leave them. Sounds like the factory amp is not getting power. Connect the amp ground somewhere to the body of the truck, making sure it contacts bare metal. Connect the the amp power to a power source, like red wire of the head unit. Or better yet, the blue remote turn-on lead from the head unit, if it has one.
Thanks,
We were wondering if that is what we needed to do, will try it out.
