Some Interior Questions
drvon
So since November my truck has received a afe cold air intake, a spray in bed liner, hurst shifter, and it's first oil change. Thanks to all of you for the advice so far, it's been great. Now my next project will be adding a oil pressure gauge. I have done a bunch of research and this is what I will be using...
http://www.autometer.com/cat_gaugedetail.aspx?gid=3944&sid=76
It's a little over kill, but I think the gauge is pretty slick. I will also mount it with...
http://www.summitracing.com/parts/ATM-15309/
The questions I have are...
Will the gauge pod work on a 2010 A pillar? Autometer says it works to 2002, which is where ford added the grab handle. The double pod pillar is to long but I think the single should work.
Also, how do you remove the grab handle and the trim on the A pillar?
I will be doing this mod in a couple of weeks. I intend to do a write up on it, since I haven't really come across a in depth install thread.
