I'm troubleshooting an intermittent starting issue on a 98 Ranger 3.0L. Mostly not starting, with it sometimes starting for no explicable reason. I believe the issue is possibly with the PCM, or there is some wiring issue in between the PCM and fuel pump relay. I've found that fuel pump relay activation circuit is not getting power with key on at the under hood fuse box. Does anyone have the wiring diagram for the PCM and Fuel pump relay? I have the1993-20111haynes, but it only has 93 wiring and the PCM is not the same. Also, is there any easy way to test the pins on the PCM, there isn't anywhere to meter the pins from. Thanks.
NVM, I can't seem to delete this thread, so everyone can get a laugh at my stupidity. I was reading my fuse diagram wrong and testing the wrong relay, the PCM relay was bad. still wouldn't mind a correct wiring diagram though if anyone has that.
