smog
bagged87
Hudson,NC
my dad had the belt off the smog pump for a long time....my ? is can i bypass all the smog and use the pump for an air pump for the air ride? it would be the same concept as using york AC pimp, but not the problems with the oil.
the only prob i see is how would the pressure switch cut it off? unlike the AC unit it doesn't have a clutch and as long as the belt is moving it would be forcing air
those pumps don't make enough air to blow out a candle.
oh..so you don't think it would fill a 3 gal tank?
