- Dec 6, 2009
- maplevalley WA
- Automatic
I did my duraspark conversion for about $300 total with valve guide seals, carb, dizzy, module. If you want down and dirty try changing the dizzy and module for around $120. Yank out the computer harness and the maze of vacuum lines. The 2.8 is pretty bullet proof as long as it is getting good oil pressure and compression. I agree with doing the duraspark conversion. pressure wash the engine and pull the intake manifold and reseal it. Put in valve guide seals you dont need to pull the heads. You dont need another carb just rebuild that one mine runs best with the vacuum advance on manifold vacuum anyway. Clean it up duraspark it and run it till it pukes I did that almost three years ago and she starts right up and goes without a warm up, and once you get the oil leaks stopped I run synthetic 10-30 and a motorcraft filter. Autolite single platinum plug new wires and she pulls a pass at 70 now where it would never do before with the computer. Do the research get the parts and dont be afraid to ask for help.
If your's runs decent, do the D/spark conversion, it will probably last longer than you think....
