Small things to do for extra power?
Robin Hood
I'm looking to spend just a few bucks.... But what can give me just a little more power. Lately I have been using a little bit better fuel, which actually has given a decent boost...
Any ideas?
'Better fuel'? There is ZERO power added by using higher octane fuel. While there are engines out there that will monitor for knock and determine the octane of the fuel being used, then adjust timing accordingly, none of the RBV motors will do so. You are doing absolutely nothing by spending more on high octane fuel other than wasting money by purchasing gas that is (quite literally) harder to burn.
There are NO cheap boosts in power. Keep the truck tuned up and pay attention to when you shift (assuming you have a manual transmission).
Power costs money. but one cheap thing you can do is advance the cam timing (cost of a timing chain and gears marked for different degrees on advance, gaskets, less than a hundred bones). I have always had decent torque increases by doing that. Stay away from anything on Ebay that says it plugs into your computer and increases power. Best power mod for a 3.0L is swap in a 4.0L ;)
Hmm. Well it wasnt my money I was spending on the gas... oh well.
Yeah 4L swap... you give me the engine and I'll do it.
haha.
Go to a 4.10 gear or bigger
then there's a power programmer from Bamachips for $400 that will give you a few horse, and they help the low end, part throttle, and over all driveability. You can get an under drive pulley from rouge (sp?) performance for $80 and they say its good for like 8 hp, I dunno but I only hear good things about them and how they help alot across the whole rpm range. Then you can do Roller rockers for $250 that are good for 10 hp I think
As far as a CAI or cat back exhaust there really no power to be had there, JBA makes headers but Ive read they dont do anything. Electric fans are junk, all the ebay stuff (Intake temp sensor resistors, Tornado intake deals, electric supercharger etc) are all crap. Someone makeaas a cam ported heads and lower intake for the 3.0 but Ive never read anything about them and there big money.
I agree. 3.0s like rpms. Mine pulls 24mpgs sitting at 3000 rpms. Running below that sucks gas.
I've been playing with 3.0s for a while now but, my best running one is stock. I just run it above 3000 most of the time.
1 roller rockers give a little hp by keeping the intake and exhaust valves open longer means more air.
2 your engine computer is not programed optimized so a new "tune" can help that( and boost any other mods)
3 bigger intake and exhaust by them selves will not improve power but together they will.
4 under pullies will not create power but they will free up some taken by steel pullies at the cost of alternator out put (only noticeable at idle)
5 or you can go turbo or supercharger.
and add all of these up
check out this site
http://rogueperformance.com/WelcometoFredland.html
Thanks for the link!
:D
do the half shaft mod (on rogues site). thats free and from what i hear, it helps. the TB is the single biggest bottle neck on these engines...so start there.
if you have a dremmel tool, port matching the heads and intake would give a noticeable boost.
if your engine isnt DIS, you can advance the timing to actually gain a benefit from running a higher octane fuel.
As previously mentioned, prob the MOST noticeable "extra power" would come from reearing your rear.
re-gearing? is that what you mean?
HOW DO YOU RE-GEAR AND WHAT DO YOU BUY TO DO IT??? I have a 94 2.3 and need all the extra power i can get out of it.
regearing the differentials for a lower ratio.
you need a ring and pinion set and an installation kit. the installation isnt usually something someone with no experience can do the first time on their own. it takes a few special tools and some knowledge of how to properly set up the gears. if you dont get it just right you will burn through your brand new gears in no time.
a downside to lower gearing is higher RPM at highway speeds.
ie lower gas milage for long trips right....but faster accel...what do i ask for at the parts store??? i have a '94 2.3 xlt 2 door Ranger 5 speed
What were you saying about a throttle body being a bottle neck???
