small grinding after shifting.
Redranger89
lancaster, pa
after i shift and press the gas a loud grind comes from the trans or t-case. happens sometimes also when going over bumps or turning. no problem with clutch or shifting. just when a load is applied. any help would be great.
i would say maybe throwout bearing now engaging all the way but that is just a guess ..
It's a sort of growling noise as you accelerate?
Likely you are upshifting at too low an rpm
causing a "lug rattle" from the trans
AD
mine does the exact thing a doent go away till i hit 1800 rpm
