92 3.0 5spd. Engine is a '07 long block with the 92 bolt on, tin and electronics. Long block has ~125k on it.
Runs great under no load. When driving, it often falls flat around 2k rpm and then it's like you added a cylinder or two as it hits around 3k. Pulls hard up to 2k falls flat, then pulls hard again at 3k. Feels like a really long turbo lag. If you floor the pedal when this happens. Sometimes it will wait a couple seconds, then return to somewhat normal power. You can hear a change in the exhaust note, it almost sounds hollow. Fuel mileage is not great. Used to get 20+, probably getting low teens now.
A bit ago, this was happening mostly going up hills from a stop, but is constant now.
Items swapped along the way (many were '92 original, so were due)-
Distributor (original had a bearing making noise, not convinced the problems didn't start with thie dizzy replacement,have thought about swapping the original electronics into this one, still have tbe original in the box)
Fresh Motorcraft plugs, coppervI think
New Motorcraft plug wires
New TPS sensor
New Cap and Rotor
New Carter fuel pump (check valve stuck in old one), new pump filter.
"New" rebuilt fuel injectors - no impact noticed on this, though I think it idles slightly better, old ones were original.
Tried a new coil, but it seemed to run worse.
Replaced o2 sensors they were due and get occasional lean code on one (IIRC) when driving at highway speed
Replaced + battery cable with original factory style, old one was in bad shape. Cleaned and tightened ground.
Fuel filter was replaced in the last couple thousand miles.
Things checked-
Vacuum- 21 and steady, snapping the throttle, it shoots to 0, then 25ish, and quickly settles back at 21 in a couple seconds.
Compression- 120 on 5 cylinders, 112 on one,so not perfectly equal, but well within 10%
MAF signal looks OK using multimeter
TPS checks out using volt meter
Misted water in the dark, no sparks noticed
Checked under hood for vacuum leaks with Ether and carb spray, none found, checked vacuum lines, manifold gaskets. Etc.
Checked for and leaks in intake tube, none found
IAC appears to be working properly.
Timing is at 10 degrees with the spout connector pulled and with it plugged in, I can see it advance as rpm increases. I do see some unexpected flickers occasionally, but not sure it isn't my imagination
Before fuel pump was replaced, pressure was a couple lbs lower than spec, assuming difference with gauge. Pressure was steady. Problem existed before pump replaced.
The intermittent code makes me think fuel, but it feels so much like the experiences I've had with two 4.6 v8's that dropped a single coil pack. It doesn't shake, it just loses noticeable power. Internally bad plug wire? I'm missing something here. Had thought plugged cats, but vacuum gauge says not likely. I'm at a loss. What have I not checked or overlooked?
New TPS sensor
New Cap and Rotor
Things checked-
