- Jun 12, 2010
- Macon, GA
- Automatic
Ok basically copy and pasted from another post. I'm getting skipping at light throttle and at highway speeds, u can't really feel is but can hear it in the exhaust. I'm also getting hesitation when I take off, but doesn't do it all the time. Also when I pat the gas and let the clutch out it feels like its flooding. Disty, cap, rotor, coil, and plugs are fairly new. Also she's durasparked so there's no computer crap
Ok I reset the float level, it was a little low, and reset the idle air mixture. I figured out my throttle plate wasn't closing enough to where it hit the stop, so I added a stiffer spring to my dual throttle return bracket. I set the idle mixture after that. Timing is 10 degrees with vac advance on ported nipple on carb. It seems to like that better then vacuum t. I have the stock 61 jets in it. I had 59 in it awhile back but plugs showed a lot of white so I went back to 61 jets and they are a little black, but not sure if its from reving and playn with the carb. Also when I rev high and let go I get a puff of white smoke, but it doesn't do it at wot with a load. Coolant is nice and new looking and the oil isn't going where its not supposed to. Except in the driveway lol. I have a 180 stat and temp guage reads 190 no higher(aftermarket guage)
Gas mileage is shitty(about 11 mpgs.
Yall think its a carb problem, ignition, or something else? Idles great and drives ok(besides the hesitation sometimes around 1500-1800 rpms(I'm guessing, don't have a tach)
Time to put my freshly rebuilt 2150 with metering block on? My intake manifold leaks oil, and when I sprayed carb cleaner around the vc the idle changed. Think that's the problem? Other then that I couldn't find any vacuum leaks
Thanks guys, I hope to get this ironed out before an upcommin trip
