- Sep 8, 2008
- Manual
About this time last year I purchased a 2004 FX4, it was/had everything I wanted inlcuding a manual transmission which is not as common as I thought.
Anyway, since that time it has been one problem after another, new alternator, new front shocks, new rear brakes and drums, pinion seal, axle seal, hub bearing, rotors and pads and new tires. All this in 10k miles.
I also flushed and filled all the fluids, new fuel filter, air filter, PVC and plugs.
Since that time, I also found the paint on the door started to chip off, turns out the P/O had the door painted, it wasn't hit or in an accident, we found out someone keyed the hell out of it. So I had the door stripped and painted right, matches 100%. (btw the car fax was clean with only 2 owners)
Long short of it, I like the Ranger, its easy of maintenance and cheap/available parts. And I am thinking had this truck been taken care of better, maybe so many things wouldn't be so wrong. But now the rear pinion is starting to hum and the seal where the front drive shaft enters the diff is leaking, more money and more work. And who knows how long the clutch will last, no idea how the P/O drove it.
I am done with this truck, I shouldn't have purchased it. So, do I cut my loses and sell it/trade it in, or keep fixing it? WWYD?
