Should i get a new 3rd brake light gasket
Gary DuBois
5+ Year Member
💻 TRS Socials
Puyallup Washington
N/A
Vehicle
Drive
Total Drop
31 inch
  • Should i get a new 3rd brake light gasket
unless it is leaking into the cab, do not touch it. plus you have to buy the whole lamp assembly to get the gasket
yea if there is no water leaking, leave it alone. Far too many times i have seen if you remove it to replace a bulb or for whatever reason it will not seal right again and then it will leak like crazy. That has long long been a weak spot for Ford trucks
If you are getting water into the lamp itself, im willing to bet that the lens has a crack in it somewhere
I'm concerned about how generic that gasket's description is, because unless I'm wrong, while some of the assemblies are close, there isn't a direct-fit-to-Ranger F-series 3rd brake light housing.
When i replaced the housing on my 98 due to the lens yellowing at the cargo lamps, the part number actually changed to the 2011-16 super duty PN. I was shocked
You can leave the Ford dealer parts life, but it can't leave you...haha
I am blown away by just how many of you guys (and gals) know what things are just by the part number!
when you run a parts department for 10+ years and still do it part time, you would be amazed the amount of useless knowledge you obtain...haha
If the lens is filling full of water and you don't want to disturb whatever kind of voodoo is keeping it from trashing your headliner (which is a common issue) you could drill a small drain hole in the bottom of the lens to let the water out.
I never understood why people mess with getting new gaskets or making them for these. Just remove the light if needed and slather on a bunch of black gasket maker. Reinstall light and wipe around the light mating area with paper towels. You can't even tell it's been done if you're neat about it.
Seriously. Blue tape is your friend here. Makes a great cutoff line.
Your right and
i was wrong i was thinking that the gasket was seperate but its built into the 3rd brake light assembly
