- Sep 9, 2007
- Age
- 78
- Manual
shift lever knob removal? IMPOSSIBLE
Hi again folks.
Seems I have to swap my shift lever from a donor transmission I installed.
It works fine but I need the boot off and can't figure how to pull the little ball/handle! It appears to just slide on to the shaft splines but I can't get a grip on it w/o damage to it? I must be missing something simple.
An aside; I found that a speedometer gear and the drilled tail housing from an earlier M50D will bolt right on a later model. Whew.
I heated it and pulled and twisted, hammered with a soft mallet, heated again..hahahahahahah I wound up chipping it off in 4 pieces just to say I did it! Now I'll buy an after-market knob
Hi again folks.
