Shackle flip... describe
Ric
...RedShred
Forum Staff - Retired
💻 TRS Socials
running/drifting over cones in Arizona
AZ - USA
O3 ranger.
I want to bring it down juuuuuuuuuuuust a bit. Nothing much. Lee talked briefly of a shackle flip for a 2" drop. With a 2" drop F/R and pulling my ABS fuse, I might be able to shave a few seconds from my times.
ready, set, describe.
a shackle flip will get you much more then a "bit" of drop.
shoeboy did it to his gen 2 and got 3-4". its a big drop.
Hmmm. Take a leaf or two out of the spring pack but then you'd lose rate.
Do a sprung-under conversion for maybe a 6" drop (I know a sprung-over on an Explorer gets you about 7") and use lift springs to get you your 2".
Or the shackle flip with lift springs or maybe Explorer springs.
That sounds like a lot of work.
Just thinking outside the box, Ric. :icon_cheers:
I think ZMan got only 2'' from doing this. All you have to do is remove the shackles, switch sides while flipping them and bolt them back on. Its fairly simple with the right tools and only cost you a few bucks for bolts. Hell, if you don't like how far it dropped you, just put it back.
They do make replacement shackles and hangers to drop the rear 2-4'' depending on the combination. You could go that way. I wouldn't remove a leaf, been there done that. Also drop leaves are an option as well. A flip kit will net you way too much and you'll probably have to notch the frame.
So, I am guessing the Ranger is turning out to be more fun than you thought?
James
I've had a pile of Ranger's but this is the first I've ran through the cones. My 96 Turbo truck had a leaf removed and it ruined the main leaf as result, so there will be none of that.
Actually, this is just interum until my 240sx is fixed. It blew a headgasket and the suspension is wasted.
if it were me, id go spring under for added stability and reduced axle wrap, then add-a-leave to gain back a couple inches and stiffen up the rear suspention for cornering. this should get you about where you want it ride height wise.
Oh the days of removing that middle leaf. My truck just kept on sagging to the point I ordered new drop leaves. Yes, you have had alot of Rangers. I remember the white one, I think that was your first?
I don't know about wanting the rear to be stiffer. I would actually like to soften the rear up a bit on mine. The front is almost perfect with the KYB MonoMax's but the rear is still too stiff with the Toxic's. I am thinking about going with the KYB GR's (I think that's what they are), they are one step down from the MM's.
James
You can get a set of re-arched or de-arched springs. I remember a company selling them a few yrs back but I cant recall their name. It may be national spring or something like that. You'll have to do a search on it. I've even seen carbon fiber custom arched springs somewhere. If you find one of these place that sell the springs, you should be able to get the exact spring rate you desire with the ride hieght you want.
James
How exactly do you do a shackle flip?? And how does it lower the truck?
CLICK
EDIT: note that the before and after pics are the same on that page. if you look under your truck right now, you'll notice the shackle is on top of the spring. a flip moves the spring above the shackle.
ive got a 96 and i pulled the bed hammerd the rivets and switched sides with the hangers it lowered my truck 2in annd i had 5 bucks in bolts. you can do this in just a few hours if u know what your doing. the cons to this was a little extra wheel hop and a stiffer ride due to compressing the shocks. i would send pics but i dnt know how yet.
If you go spring under, you could run Belltech's to regain some height. It may mess with ride quality, but its an idea...
Just a thought, but maybe you should consider this, but instead of using another leaf, use an air helper. A buddy of mine has his 95 done that way, and it hooks up nice.
It's a pretty easy conversion, just grind off the rivets and switch sides and use grade eight bolts with nylocks, or lock washers. 93-97 gets 2 inches, 98 to ? gets 3 inches.
Bolts
What size was the grade 8 bolts u had to put in place of the rivets? I am new at this
