Was out this evening. Had taken our 2002 Explorer with 4.6L.
All had been fine. When we went to leave, cranked the engine, it started and a second later it starts making horrible and loud noise. Shut it down immediately. Initial thought was that some serious mechanical failure occurred.
Opened the hood, didn't see anything obvious, so restarted while watching engine, immediately it was obvious sound was coming from a spark plug hole. Pulled the engine cover and found plug and coil pack had been blown out with the plug still in the coil pack and the whole assembly hanging by the wire.
What the heck causes that to happen? Got a plug socket, ratchet and extension and was able to put the pug back it. Thrads on the plug seem fine and it didn't seem stripped. So my only guess is that the plug must have been loose. It been over three years since they were worked on. Loose all that time? Seemed to be running perfectly fine. Only hint of anything is that it seemed to have a tapping sound that had been getting louder. When I get the coil pack replaced (it was damaged beyond re-use) I will see if it has that "tap" or if it got quieter.
I am just dumfounded that this happened.
