I have a 94 Ranger 4x4 that was (so I was told) run into a ditch.
The damaged driver side radius arm bushing bracket and both radius arm bushings were replaced. Those where the only parts that showed any kind of damage.
All the upper and lower ball joints seem tight.
The camber was adjusted all the way to get it from / \ to | | .
Problem is this...
* When you back up the truck, the camber changes from | | back to / \.
* When you pull forward, it corrects (but not totally).
1. Why would the camber change so much from reverse to forward?
2. What other adjustments could I be missing besides the upper B.J. cam?
3. What other parts could be wacked?
PS: I can not attach photos
---> (new user?)
Thanks in advance! Mark
Problem is this...
