seen a weird suspension today?
cut and turn beams, two ways of doing it.
1) is to cut the lower ball joint out, and move it out to correct camber
2) is to cut the beam its self and turn the end up.
the reason for cut and turn beams is to correct camber from lift,with out the need of beam/axle pivot drop brackets
myself I dont see the reason behind that spacer.other than, it what was around, but not something I would do.
Upcoming TRS Events
