- Apr 16, 2013
- Manual
I blew the head gasket on my 231k mile engine. There was some sediment in the overflow tank and it was empty when I checked a couple days later, plus the chocolate milk as oil. Replaced the engine with one that has 121k miles and looks in decent shape. Replaced water pump, thermostat, spark plugs, spark plug wires, timing belt, hoses.
Radiator was not replaced. The shop flushed the radiator. Coolant in the reservoir looked fine when they gave it back. I've noticed every few days I seem to get more sediment in the overflow reservoir now. I've vaccuumed the reservoir out, cleaned it with a hose, vaccuumed that out, then refilled coolant. Same thing happens every few days. My Mountain Dew color coolant turns slightly dirty and I seem to get some sediment that settles at the bottom of the overflow reservoir. I repeated this three times with same result every few days over a span of about 700 miles.
Does it likely need another flush? Suggestions?
