Scott5640's build v2.0
those 15s or 16s?
UPDATE!!!!!!!!!!!!!
body lifted!!!!!!!!!
now i have problems...
1. i snapped the head off a bolt for the cab...so i gota fix that
2. the steering seems stiffer now?
3. the truck seems like it runs rougher now...like it idels bad
next things are cut the bumper more and fix the rear bumper and exhaust
i would say mine got a bit stiffer on the steering, but it feels normal now.
and sure its idleing bad or its just vibration?
thats weird, you sure u didnt unplug anything?
i know i didnt...oh well itll break eventually...
check the vacuum connections on the engine, maybe u unplugged one accidentally.
if the CEL isnt on i doubt its something electric
I agree with RSH... it could also be a vacuum hose that got broken some how, I had the same thing happen to my pickup and at a stop light, the truck would go up about 300 RPM's, and it would try to move forward. Found the leak, turned out that a hose clamp had come off and tore the hose.
its not revving higher, its just dropping 20 or so rpms and going back up
sounds like a vacuum leak to me
sure u didnt smash any fuel hoses with the bed?
all the ground straps are making a good contact with the frame?
misses when u rev it?
That thing looked pretty sweet without the BL. Still lookin' good though. What kind of tires?
Not bad at all man.
What else does it do besides idle bad? It's kind of a generic term. Does it misfire? I would wonder if maybe you hit a plug wire or something. Make sure all the boots are snug. After that, Try running the truck and have a look...Sometimes watching it run and kind of poking around will find the culprit. If you hear hissing, look for a vac leak. So easy to break / knock off those lines.
