standard sized cabinet, 16"wheel is difficult to do.
I have a 48x36x24 cabinet you can have if you pick it up...
Time to build your own cabinet.....
One you can walk around inside.....
A couple of BB 460's with half the cylinders used for compressed air.....
A dump truck to haul the sand....
kind of working on it.
I'll stay outside.
problem is the valves. need exhaust valves that don't open until full tank pressure or the tank will "refill" the cylinder
before the cylinder fills the tank.
Hmmm,, hinges easy to do. can use the ram from an engine hoist to raise it. throw on some cobbled up duallies
and swap in a 2.9 for MORE POWAA
You jest, but GWAII did it. Might have been a 2.8L, but it was same basic engine he converted to an air compressor for his tarp garage. Wander how the GT-12 is coming along.kind of working on it.
I'll stay outside.
I suspect there is a big difference in sealing between 15-20 lbs of boost and 150 lbs of boost.Semi-serious?...how about a belt driven supercharger with the outlet feeding your compressor tank?
