- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
I'd be curious to know if Ford ever had any recalls or TSBs regarding leaves that get inside and collect up against the blower motor resistor inside of the evaporator box (blower housing) starting fires.
Twice now I've had a strong smoke smell come from my vents while running the fan on it's 1st (lowest) setting. Both times it was leaves in there (the leaves had coil-shaped scorch marks on them from the wire resistor).
When I got my BII in '04, this was one of the first things I checked on it too. Same thing, plenty of leaves piled up in there, though they hadn't quite made it up to the resistor yet.
I'm the original owner of my '94 Ranger, never once seen any notices about this.
Something you guys with '89-'94s might want to check occasionally if you ever park where leaves might fall (or be blown) onto your truck. (not sure if this affects earlier or later years)
