Dweano
I'm trying to put on headers and failing hard core. The y pipe catalytic converter connecting bolts rounded off...time to whip out the grinder, which isn't really too bad. But trying to remove the EGR tube is a major PITA, I have to use open ended wrenches (look under your hood if you don't know what I'm taking about) and so far the wrenches just slip. Not too long down the line i'll have rounded them off. I haven't even begun the head bolts yet, to be honest I'm scared. I sprayed the EGR tube with penetrating oil daily for about a week, no apparent help. I've also sprayed the head bolts and praying that will have an effect. I used normal stuff and the freeze so the rust cracks and penetrating oil gets in blah blah stuff. I figured why not. Also I think i heard that in impact wrench works good. Any other words of advice for getting stuff unstuck? Not only for headers, because many a time I have had this problem.
P.S. What size are head bolts, 3/8 is too small, 7/16 is too big? 11mm too big, 10mm kinda too big, 9mm too small???? Are mine messed up or do i need something special. Damn you header project...
