rubber/wheather stripping window kits
87Ranger4me
Eagle Point OR
Anybody know where to find a complete rebuild kit for the windows on my 87 Ranger? I need all the channeling and rubber and the bottom rubber that your arm would rest on if you had your elbow resting in the window, (does that make sense?) I'm not sure where to start, I thought about a car glass shop but have not checked with them yet. I'm sure Ford no longer carries them. Any help would be appreciated.
LMC Truck
I got the anti-rattle kit from LMC along with new door gaskets for my '88. It's pretty easy to do. The rubber strips along the top of the door just have some metal clips that clip on inside the doors. You have to pull them straight up to get them out. Don't scratch your paint like I did!
As far as the window gasket around the inside of the window frame goes, I pulled it out starting at the top. It goes pretty far down the window channel towards the back of the door. My first door, I took the door panel off and then I figured out if you spray the gasket with windex, you can slide it all the way down without having to take the panel off. You'll have to trim a few inches off the end at the front - just be really careful how you measure it. I cut my first one too short and had to cobble some pieces together to get it sealed.
Napa has full door weatherstrip kits. I'll try to grab a part number tomorrow
Hey thanks guys thanks for all the input, i was beginning to think it was going to be hard to find. I have a Napa just a mile away I will wait for that number otherwise I will go the LMC route.
