- Nov 2, 2008
- Manual
Just wondering if anyone else has this problem or can tell me how to fix it. Engine runs rough, especially when first started, until it reaches a certain rpm. I don't know what rpm because the tach doesn't read right(another problem I'm trying to figure out). I was getting on the highway after work. Got to 3rd gear and pressed the pedal to a point where it was still accelerating and held it there. The truck ran really rough but when it got that certain rpm, it's like something adds a bunch more power and it smooths out almost like it had a dead cylinder and then starts firing on all four again. I've changed the O2 sensor, fuel filter and all 8 plugs. Could it be one of the coil packs? Plug wires? One of the codes I got out of it had to do with loss of dual plug input control. Any help would be greatly appreciated!!
I have recently noticed that when I first start it on a cold morning, it runs perfect. After a few minutes, it's back to running rough. I've been told it could be the ignition control module or crank trigger. Could it be the coolant temp sensor or throttle position sensor? It will run great if it is at full throttle.
Thanks
Thanks
