- Dec 23, 2009
- Automatic
i have a 97 mazda b2300 4cyl. if u let it idle for about 10 minutes it will start missing really bad. sometimes while driving it will do the same and barely pull its self then it goes away. i replaced the timing belt and the cam was out of place by 2 teeth. after i did that it was significantly better. actually pulled its self down the road. but if u pass someone and hold it floored for a few seconds after u let off it misses real bad like it is getting to much fuel. if u hold it floored at about 70 it quits pulling for a second and starts to again. i know this thing isnt fast at all. i just think it should run better and not act so funny. idk if this stuff links together or if it has multiple problems. where should i start?
