Rocker Arm bolts - help locating some.
Umpire4321$
Greetings,
Ok, I'm about to lose my mind - I'm in need of (6) rocker arm bolts and the apparently the bolts don't exist except the ones I pulled:
1995 Ford Ranger XLT Extended Cab
3.0 V6, 2WD
The bolt removed is a Flanged M8 1.25 10.9 35mm Dog End, 10mm hex head w/17mm (thereabouts) flange. The tech diagram located on this site is 33mm in length.
Anyone have a source for such a bolt?
Thanks!
I would look to a bolt supply warehouse near you.
my local DoitBest has bolts matching those
