Rock Auto Order
Yeah, I watched that video but I didn't have a good idea what it was so I didn't make a guess.
Maybe try taking the belt off and wiggling the pulleys to see if any of them seem loose or if they have a bad bearing.
I've had noisy pulley bearings and tensioners on several vehicles but none of them sounded as harsh as yours at startup.
hmm, that's not a bad idea, is it just a 1/2" drive ratchet to pull the belt off?
if it was a wobbly pulley, would it make sense that it stops right after starting?
I think it's actually a 3/8" ratchet. It might have changed from the vehicles I've worked but it's still pretty simple to get off.
It's worth a try to check the pulley bearings, it might not be that at all but at least it's easy to check.
that's true... maybe i'll check that tomorrow during the day..
I watched it again, and I have my doubts about it being anything accessory belt related. It almost sounds like it's more of an exhaust type sound to me. Maybe someone who's more an expert will jump in here and be able to tell you exactly what it is.
ok, so i'm doing an order from Rock Auto, for the parts that i have defiencies, and since i figure it's 25$+ for shipping for 1 item, and about a dollar for each additional item, it's best to get a bunch... my truck is at 96,200km so it's getting close to a "major service" according to ford, the tires have been rotated, oil, differentials, transmission and transfercase have all been drained and re-filled, what am i missing from this list, that i should tack on?
also, i'm only ordering things that will ship from the same location, which is why i am not getting a replacement O2 sensor (mine is throwing codes)
list:
-MOOG Part # K80068 Control Arm w/Ball Joint
Frt Susp; Upper; RH; 4WD; 1 piece design; Incl. bushings (problem solver)
-Air Filter
AUTO EXTRA Part # 61946253 (quantity of 4, because they are $5)
-Fuel Filter
WIX Part # 33424 {#G9343} (quantity 1)
-Differential Cover Gasket
FEL-PRO Part # RDS55341 Rear Axle; 10-bolt holes; Visteon 8.8" R.G. (quantity 1, don't need it, but i figure i should hold onto it for next time)
anything else i should grab while i can?
where do you live that shipping is $25..........you should be able to get an O2 sensor shipped for about $5 and you get 5% off so the shipping is usually insignificant on an o2 sensor :icon_confused:
also remember that you get huge discounts by purchasing parts from advance auto online and then picking them up from the store........I do it all the time!!!!
canada
the total shipping i've got so far is $44.48 canadian, the 5% discount doesn't count for shipping, it's parts only.
even with the huge shipping charges, i'm still looking at like 30-40% off of local shops, if not more... the more i buy, the greater the discount, because shipping doesn't go up as fast as the cost of the parts do, due to the initial charge of like 25$
as for the video, i really don't think it's the starter, but i'll check that when i'm looking at it today...
(the total shipping i've got so far is $44.48 canadian)
that's what I got on the shipping charge last month for my order piece
has to be beyond this amount must be ordered at $ 300 more
i don't know what you just said... but my total parts, and shipping is like 198.87 or something like that...
Rock Auto Order
