rims for blitz mid travel
swickwake
Porterville or Chico Ca
i need rims to fit the blitz mid travel kit. stock rims will not work. i know i need 3.75 back spacing but i do not know the offset.
-6mm or -19mm
backspacing is offset if i remember correctly
Yes, and no.
Backspacing is the measure from the inner bead to the wheel's mounting flange (in this case, we know that 3.75BS is what is needed)
Offset is the measure from the wheel's center-line, to the wheel mounting flange.
To find your Offset, take the wheel width (lets go with 8") divide it in half, and you get 4" (center of the wheel). Now you subtract 3.75" from 4", and you get.25". Lastly you convert that to mm, and you get your offset. I'm not sure about whether it would be positive or negative offset, that would be a good question for google.
I hope that makes sense.
-6mm or -19mm
well i got a set of semi-flat aluminum wheels on my ranger id sell ya that would work for your truck (all my stuff was converted to 5 on 5.5 when i went long travel) but i gotta check with odie to see if he wants them, he ahd dibs on them first :D
thanks for the help guys i found some rims in summit racing that worked for my application.
as you can see in the front.
wow that thing is jacked up (course the 31s dont help too much :D) pics of the kit please!
thank you. I'm not the only one running a lift and fiberglass with 31"
haha this thing is ridding on 30's what doesn't help is the fact the there is ford motor company suspension in the rear. that will change in the next 6 months.
but i am very happy with the dent that this kit has made in my pocket. today with it loaded down close to max i put 300 plus miles on it. it handled like a dream.
will get pics of it up tomorrow.
