85_Ranger4x4
Wallows in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- SW
- State - Country
- IA- USA
Back in the 1970s some people thought that gas fumes inside the gas tank were a source of "air pollution"
So the Evaporative emissions system was invented, EVAP for short
Gas tanks had a Vented Gas cap up to that point
So gas caps were change to un-vented and a hose was run from the top of the gas tank to a PORTED vacuum source on the carburetor
Ported vacuum has very little vacuum at idle and then gets higher vacuum as RPMs go up, so opposite of regular vacuum, and not as strong
Gasoline in the tank creates more gas "vapor" when its sloshing around, vehicle moving, which is why Ported vacuum was perfect, it sucked in more vapor when vehicle was moving, which was the point of the EVAP system
And the vapor was just burned up in the engine like the gas from the Jets(or injectors)
Then a Charcoal canister was added on the hose to gas tank, so fumes/vapors would be filtered even when vehicle was sitting and off
Then when vehicles got computers the powers that be decided that this ported vacuum method could be refined, and more expensive parts should be used, lol, many many more parts
And we have this now-a-days: https://www.motor.com/wp-content/uploads/evap1_0317.png
Computer uses the purge valve to control regular vacuum sucking fumes from gas that thru charcoal filter
Computer has a vacuum pressure sensor on the gas tank to make sure pressure is not too high or there is no pressure so a LEAK in the system("Check gas cap" light on the dash)
And then a computer controlled Vent valve to pull in fresh air to charcoal canister as needed
This diagram has flow indicated: https://s3.amazonaws.com/rparts-sit...rts-and-vehicles/evap-system-diagram-500x.jpg
So what started off as a nice simple system with one hose.......................well engineers MUST engineer, lol
Rube Goldberg machine comes to mind![]()
Canister was also moved from the fairly clean engine bay to the dirty enviroment above the rear axle/spare tire so the delicate valve can plug with dirt, and they have a pump to also fail now too.
