replacing rear window
You can probably do it. You do want to ensure the replacement gasket has the "join" between the two ends on the bottom of the slider. Care in removing the old one, caution
installing the new one.
Seems like it takes a 9mm deep socket (1/4 in drive) to make the job considerably easier.
Did my own several years ago (2002, maybe?) -- was the first change made on mine -- no leaks so far?!
Doesn't hurt to visit with "contacts" at a vehicle glass shop for pointers!!! Listen carefully!!!
