Removing corner light?
02RangerXLT
NE
How do I remove the corner light on my pickup? (The one separate from the headlight). I would like to know if there's a way to remove it without removing the whole headlight assembly. For some reason both the turn signal and marker light bulbs both burned out (WTF).
Thanks
You won't have to remove the headlamp completely, but you will have to release it for access. Pull-up on the 2 tabs that hold the headlight in place. Wiggle the headlight assembly out of the way, then you can access the 2 screws that hold the corner lamp in--I believe they are either 7/32" or 5.5mm-either should work. Once the screws are removed, give it a good tug-there is a snap-type fitting holding it in place. Come to think of it, you might be able to change the bulb without removing the corner--it's been a while.
MikeR
