- Apr 21, 2021
- Automatic
I have an 83 ranger with a 302 in it. One of the things I am doing to it is building a new dashboard, so I removed the old one. I left the ignition switch on the column alone though. Now, the truck will not start, even though it started fine before. The starter turns, and the carb spits fuel but thats it. I replaced the ignition module (duraspark 2), nothing. I replaced the distributor cap, nothing. I made sure the coil was not broken, still nothing. The only thing I can think of is somehow the signal is not being sent to the coil to send out a spark.
I looked over the wiring using the diagram below:
and everything still checks out. It is worth noting that I bought the truck with the 302 in it, and it ran. the 302 uses the same ignition system as a stock 83 ranger. Is there something I am missing from the igntion system that would prevent the spark from not being sent out? some sort of security device that got disconnected? The next thing I want to replace is the sensor in distributor that sends a signal to the igniton module, but idk ehy that wouldve broken. I do want to rewire the truck and remove most of the non essential wiring, so would yall suggest just doing that now?
