relay
87Bronco2problems
10+ Year Member
i fount somethin that is on the passenger side under neath the hood that was mounted to the fender.....i poped it off to look at it and it was corroded....now she wont start at all...tested the fuel pump before i put it in and hooked it up....now it aint workin...so i figured it was an electrical problem....could this relay or wat ever that is corroded be my problem?....i need help plz
Well it worked, then you touched it, now it's broke.
Good bet that is your problem. Go buy some CRC contact cleaner and clean it all up real nice.
