Red and black hoses for the heater
Optimaldave
Vancover, BC
Hi, sorry if this has already been posted but I couldn't find it when I searched.
The previous owner of my truck straight bypassed the heater core going block to block instead of block to heater-heater to block.
So there are two hoses coming through the firewall. One red and one black, and I was wondering if anyone could tell me which one is "in" (into the heater core) and which one is the "out" hose so that I can hook up the heater again.
Cheers
Normally, the hoses are the same color. They have been changed. If the hoses are the same size, it doesn't matter which goes where. I usually go from pump to heater's drivers side connection, or to the top connection whichever the heater has. Return hose to pass side, or bottom. If the connections are a different size, it is self explanitory.:)shady
so is the heater core non-directional?
The hoses are the same but in my ignorance on the topic of heater cores I don't know if it could cause problems to hook-up the heater core backwards...
cheers
no the core can work in any flow direction, bud there is a vacumm hose and a shout off vavle in line of a "stock line lay out" so if it does not have that then u need to find the vac line a plug it
On a 1990 ranger there is no shtoff valve in the heater core flow path.
It does not matter which way you hook up the heater core.
AD
