Recommended Oil Pump
Front Range
CO - USA
Vehicle
Ford Bronco II
Drive
Stock
I will be pulling the engine to replace a leaking oil pan gasket(and other leaks). I will replace the pil pump while its out. Should I stick with a stock unit or get a high volume or pressure pump?
Stock unit it is then. Thanks.
