- Nov 26, 2009
if you run 19lb/hr injectors in place of the stock 14lb/hr injectors without pulling fuel pressure down to compensate you will be dumping 35% more fuel at current injector pulse widths than stock.
your MSD ignition components aren't going to help you burn 35% more fuel, MSD's "Multiple Spark Discharge" helps an ignition system burn the fuel it already has more completely. by firing your spark plugs several times in rapid succession. MSD coils, are a slightly stronger coil, but by itself doesn't do much if anything, MSD caps, rotors, wires etc. are just a higher quality replacement part. They won't help you burn more fuel either.
hope this all made sense
