I used exolorer leaf srpings and belltech extended shackles to gain about 4-5'' ith the stock block, add a couple of the ranger leafs into the expo pack and im sure you could get the extra inch as a cheap alternative, depending on what your looking for, if im not mistake lift leafs are pricey unless you come across a deal
I used 64" Chevy springs, and Chevy 2" drop shackles and my stock blocks. That combo got me 5". I think I will weave a Ranger leaf into the packs if I need to go 6".
Ok, here's an idea. The 63 1/2 chebs involve moving the front hangers forward a few inches.
How long are stock ranger springs? Like 54 or 56 inches or something?
Why not use some 52" 3/4 ton chebs and boomerang shackles or taking a few leaves out of the pack so it squats out to get a decent shackle angle. With 4 leafs in my pack, they're holdin up the front of my truck. Somethin to think about.
If you pull the bed, moving the fornt hangers forward doesnt take much. You can reuse the front bottom hole in the frame, so all you have t do is drill three more holes, and weld a tab on the hanger so the front top hole can be relocated. If it is a Super Cab the cab mount will have to be notched and and tab welded between the frame and the back of the mount to support it where the bed bolts on. I was lucky enough to get Chevy springs with good bushings so I didnt ahve to experience removing the spring bolts.
thanks for everybodys advise
i think i am just going to go head buy the ranger six inch springs
little pricey but they will bolt right up and do not have to remove and or replace
brackets some dont mind paying little more if i can make my build easyer
thank again still pretty wet behind the ears every step of this is a learning experience
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
