rear driveshaft help!!!???!!!???
parson2008
Wisconsin
i have a 93 extended cab 4x4 with a 4inch lift. i want to do the 1 piece swap, and illiminate the mid bearing problems. What year 1 piece driveshaft will work? my truck is also the 5-speed manual with the 4.0. is there a special kind? thanks
you need a 98-2000 extra cab 5-speed steel or aluminum. it can be from a newer truck, but it has to have a 2.5" bolt patern on the front flange to bolt to your truck, or you can get the larger 3" flange from the transfer case and bolt it to your t-case and the newer 3" ones will bolt in also
