Rear brakes chatter...
helpme
15+ Year Member
Hotlanta
Rear brakes chatter when taking off, after stopping. Drum brakes. Like rear brakes not releasing. Is that the pistons seized up in the wheel cylinder bore? Or is it a proportioning valve problem? Goes away after you get moving. Pulled the drums off and everything looked normal. The drums weren't stuck either. A little background. Started after changing the brake booster. I used the tool to set the pin adjustment. I think I got it right. Thanks.
